Does it go out when you start it up?When i switch the key on befor i start it the check engine keeps blinking , it used to be just on with out blibking
Is that a problem ?
Make sure you plugged everything back in. It sounds like you may have left your map or maf sensor unplugged.Thankd for replaying , but it feels wierd that every thing just works fine now
I just have ine problem for now that is when i start the car first thing in the morning the rpm keep going up and down for two or three times
I cant tell where is the problem coming from i cleaned the throttel body and it works for week and back to the problem any idias![]()
Hi rany e j,Thankd for replaying , but it feels wierd that every thing just works fine now
