I have an idea that I want to try on my doors but I need to know what the doors look like with out the skins so does any one have a photo of the front doors unskined......."BODYSHOPS","customizers"and collision shops I need your help. Any info will help,,,,Thank you in advance. P.S. Its an 06
Discussion Starter · #2 ·
Any help on this??????ANYBODY
I'm sorry, but what do you mean by a door un-skinned??
I need to know what the frame of the door looks like,as if you peeled the door skin off of it,where the supports are located.
You're not putting tv screens on your doors are you? I don't think there is such a picture. Unless you physically peel one yourself. Then it would be the first.
Sent from Galaxy.....S4 that is
NOOOOOO, I am not going to do that. I have another idea.
There is a bar going right across the center of the door. Take your door panel off and you can see inside.
Why didn't I think of that to start with(DHUUU),do you know if that is the only bar in the door?
In the center yes, but there should also be some sort of brace at the top and bottom. What exactly do you have in mind? I can tell you if its doable or not.
You also have to worry about the window regulator and window as they are fairly close to the skin
