1 - 12 of 12 Posts
I know dumb ? but is the negative battery terminal the one that is hooked up to a small painted (red) screw into the body of the charger? I see the red terminal because it has the BIG + on it but negative ummm HELP!!!!!
The battery is in your trunk under the floor mat.
The red terminal in the engine bay is just for easy jumping if your batery is dead.
Look in the trunk, it will look familiar:grin:
I think the instructions tell ya to disconnect the battery to reboot the PCM to learn the new better breathing intake
Discussion Starter #5
thank you kindly for the response. I am installing AFE and predator and want to wake Hal up... shhhhhh
But if he is doing the Predator and resets the adaptive learning that should do the trick.
Discussion Starter #7
where is the 12" weather strip that is mentioned on mopar CAI install thread i dont have such a weatherstrip i only have the big one for teh heat sheild on AFE. Am i missing something?
Discussion Starter #8
also guys when i disconnect the negative terminal on battery what will I need to recalibrate if anything? and if so how to recalibrate?
You really shouldn't need to pull the battery. If you really want to reset the PCM after the install, just pull fuse 11 (under the hood) for a minute.
Won't the Predator do the same thing without the reboot?
I don't think I disconnected mine when I installed the AFE stage two is that Bad ??? oooppps.
1 - 12 of 12 Posts
