Hi I bought fog lights for my 07 charger 2.7 se. It's pretty simple to install with the switch they provided. It has relay fuse everything including a switch that you connect through the harness. I want to connect them to my parking lights, but i dont know how anybody help me out. Should i tap into cables from the corner lights?how? or can i tap into the light switch?how?:confused: or should i just leave it like it is to the aftermarket switch?not my favorite option though.
I wouldn't tap into anything. I would install like it should be so you don't risk blowing a fuse or worse...
Don't make something simple more complicated
Run a separate power line and switch then you won't have to worry about blowing a fuse.
