1 - 13 of 13 Posts
remove the all the electrical tape so you can see all the wires..
Cut the dark green wire that has a white stripe.
Then use a wire tap and tap it into the white wire with the green stripe coming from the other bulb..
Tape up the end of the green wire that's coming from the connector.. You won't be using it.
1 - 13 of 13 Posts
