I will be cleaning up my tail pipes they are built up good with carbon. what will work to clean them?
Sent from AutoGuide.com App
ACES IV with a brush makes a great stride in cleaning them up.I will be cleaning up my tail pipes they are built up good with carbon. what will work to clean them?
Inside, outside...or both?I will be cleaning up my tail pipes they are built up good with carbon. what will work to clean them?
Yep. But it's hard to get the nooks and crannies on the inside between the pipe and the tip. That's where a spray to dissolve soot like WD-40 comes in handy.Warm water and an SOS pad, best cleaner ever for stainless steel
I would use a tooth brush with stiff bristles
That's a good way to scratch the hell out of them.Warm water and an SOS pad, best cleaner ever for stainless steel
You've got to be kidding me...ACES IV with a brush makes a great stride in cleaning them up.
Then you have never tried it, the SOS pads are designed not to scratch and leaves them looking like chromeThat's a good way to scratch the hell out of them.
Yeah; I've never cleaned anything with an SOS pad in my life.Then you have never tried it, the SOS pads are designed not to scratch and leaves them looking like chrome
No, actually I am not. ACES IV gets the carbon off things much better than any other cleaner. Remember it contains a combustion chamber cleaner so it will work well on the residue made by a combustion chamber. It isn't a polish but does do a great job on any carbon.You've got to be kidding me...
I agree, the reason I know is because I've used them on stainless steel pots and pans...swirl marks galore!Yeah; I've never cleaned anything with an SOS pad in my life.
Trust me an SOS pad, and even those plastic scrubbing pads like the mr clean ones will leave major swirl marks and scratches.
NEVR DULL is the easiest and safest way to clean them.
I literally just went outside with a magic eraser, got on the ground, and scrubbed the tips on my mustang to make sure I'm not full of BS. Yeah, no scratches. I'm about to leave but I'll try to make a video or pictures or something :beerchug:I used a mr clean magic eraser on Mrs Flex's stainless steel kettle and scratched the hell out of it.
So glad I wasn't silly enough to try that on my exhaust tips.
