We really can't help from where we are without the codes. Anything else is a shot in the dark....minus the tbody light. That just means there's an issue with the throttle system...tbody, throttle position sensor/ gas pedal.
My bad didn’t realize I didn’t post them. The thermostat code has been there but other than that couple different codes came up C121C-00 - “torque request signal denied” which makes me think the sensor for the throttle is possibly bad and shut the car down? Other than that
P2172 : High Airflow/Vacuum Leak Detected (Instantaneous Accumulation)
P0038 : 02 Sensor 1/2 Heater Circuit High
P0058 : 02 Sensor 2/2 Heater Circuit High no other codes and those 3 were labeled “secondary DTCs” Im lost honestly spent 5 hours in the side of the road trying to figure out what it could be unplugged and plugged in map sensor took intake and tube off to spray some starter fluid into the throttle body to try and get a spark to see if it was the fuel pump still wouldn’t turn. Tried jumping it. Wanted to disconnect the battery to try a reset but didn’t have a ratchet with me and I tried the pedal reset nothing ended up pushing it to a gas station for the night unfortunately couldn’t get a tow and going to try and get it to a shop tomorrow or Sunday
