You may try this.
SUBJECT:
Multiple Cylinder Misfire Or Rough Idle
OVERVIEW:
This bulletin involves rotating all engine exhaust valves, replacing the valve spring retainer
locks with a new design to increase valve rotation at lower RPM, inspecting/replacing the
MAP sensor (as necessary), and decarbonizing the combustion chamber.
MODELS:
2004 - 2006 (CS) Pacifica
2005 - 2006 (LX) Chrysler 300/Magnum/Charger
NOTE: This bulletin applies to CS models built after February 1, 2004 (MDH 0201XX)
equipped with a 3.5L engine (Sales Code EGN).
NOTE: This bulletin applies to LX models equipped with a 3.5L engine (sales code
EGG) except 2006 vehicles equipped with California Emissions (sales codes
NAE) built on or before May 2, 2006 (MDH 0502XX). See Technical Service
Bulletin 18-016-06 dated May 4, 2006 for more information..
SYMPTOM/CONDITION:
The customer may experience occasional engine misfire (rough running engine) during
certain vehicle operating conditions.
In addition, MIL illumination may also have occurred due to Diagnostic Trouble Code
(DTC) P0300 - Multiple Cylinder Misfire. Various single cylinder misfire DTC's may also be
present. If the frequency of misfire is high, the Powertrain Control Module (PCM) may
place the engine in “Limp-In” mode.
The misfire condition may be caused by one or more engine exhaust valves that are slow
to close due to a build up of carbon on the valve stem
