1 - 4 of 4 Posts
I have read various posts regarding the stalling issue and am confused. I have a 2008 Charger 5.7L Hemi Police Interceptor, the problem I have is when engine is cold, after sitting for a long time >8hrs. Once I start engine for the first 5 miles or until gauge reads warm at slow speeds or at a stop my engine just quits. There is no warning this will happen it just shuts off. After warmup all has been fine. There are no codes or check engine light associated with this problem also. I have changed all plugs/coil packs, installed new heavy duty battery and crankshaft position sensor all to no avail. I have read there is an ignition switch recall outstanding, unfortutunatly there are no parts to fix the recall. Could this issue be non recall related? What other fixes can I try to resolve this issue?
Thanks
Ilya
Hmm...idk how much it would have to do with it, but-- have you checked your ignition coil? Those things go bad on the Chargers quite frequently. And I know for a fact there have been some recalls there as well. Only other thing I would suggest is a fuel line cleaning, and maybe you just got some air in your gas lines last time you filled up. Idk man. My friend had the same problem but I forget how he fixed his. Ill ask.
Thanks
Ilya
Bad ignition switch could be your problem,here's an article about bad switch:
http://www.nytimes.com/2014/09/26/b...hicles-for-faulty-ignition-switches.html?_r=0
Hi THVGJP,
Welcome to the forum! Sorry to hear about your stalling concern. Is your vehicle equipped with remote start?
1 - 4 of 4 Posts
