1 - 14 of 14 Posts
I have an 18 Daytona 392. I want to change my grill to the hellcat with the intake tube. Does anyone know if the intake tube will work with the factory Daytona CAI box. It has a cut on the front and looks like it will.
Thank you for any help.
Are you talking about using the snorkel from the Hellcat to go into the lower airbox of your open top Mopar CAI (that I think was stock on Daytona 345/392)?
I'm not so sure it would fit, my 2019 R/T has a round opening on the front but I've read that it still doesn't mate up to the Hellcat snorkel.
Worst case you can buy the Hellcat upper/lower box and sell off your current parts.
295084
15990671407605906577631977012351.jpg Yes the snorkel. I have a square cut out just didnt know if it would work. I've priced the hellcat boxes just like the open one. Since 2020 come with the grill and snorkel was hoping they would line up.
295086
The Hellcat snorkel is round on the side that fits into the air box (see the end with the tabs on the right).
Based on that alone it won't mate up without you fabricating something. Would probably be easier to just swap the entire hellcat upper/lower box at the same time and sell off your OEM "cold air intake"
I would dig into Youtube and see if anyone has done the swap. I think RacerX might have talked about it he has a Shaker Scat pack not a Daytona. The Bottom part of both air CAI systems might be the same as far as size and fitment.
This might be a cool project if this works
It's not really a bad job to do. Will help with intake temps at idle. If a 19 grill installed then at speed it does help having this mod.
I swear some of the newer OEM cold airbox have the hole already, like a Redeye lower airbox
Yeah my 2019 R/T has a hole in front of the stock airbox but I don't think it mates up directly to a hellcat snorkel plus the box design isn't same on upper or lower lid as the Hellcat style:
295291
The Hellcat lower air box will fit with any of the stock tops (2015 up -- not sure about 2011-2014) I have the top of my 2016 V6 box sitting on mine, fit perfectly
10-4 the problem the OP has/had is that he has the open top Mopar "cold air" intake found on the Daytonas and his lower box has a squared off opening in front that won't directly take the round snorkel without some fabrication or just replacing the upper and lower together and ditching the blue Mopar filter.
I see the large difference in the bottom of the box as far as the shape and surface area comparing V6 to 5.7 and Hellcat lower box... are the tops all the same? I guess I never looked closely.
The shape of the tops where they attach to the lower box are all the same, but the outlet pipes are set a different angles, lengths, and diameters for the various engines.
1 - 14 of 14 Posts
