Hi all,
I just recently purchased a 2nd hand Dodge Charger SXT from a dealer that had only done 7000km. All seemed well. Then 2 weeks later as the weather changed I attempted to raise the temp by pressing the UP arrow. I clearly saw the temp was increasing, but the air was still cold. Even when I placed it at HI (max temp).
The temp only works if the Recirculation Button is pressed. Once this button is pressed and you moved the temp Up or Down, it will then fluctuate. However once that button is depressed (not illuminated) the temp controls will work, however not change the temperature.
Any idea's on this fault?
Thanks
Sachin
Thanks
Sachin
