I had someone replace my instrument cluster glass over the fuel gauge (It had a crack in it). When they put it back together, they forgot to hook the headlight switch back up. So I took it back and apparently a different person worked on it and scuffed the plastic a little while trying to pry it out.
However, since I've only had the car for about a week (bought a slightly used '07 SXT), I can't remember how tight the headlight switch's panel was in the dash. If I wiggle the knob and slightly pull on it, the panel behind it moves just a bit. Is it a little loose to begin with anyway? (Thought the headlight switch modders might know the answer to this.) I don't want to sound too anal, but if they messed it up, I'd like it fixed.
