Charger snorkel go in the left side of grille by the headlight from the factory there is a baffle blocking the opening that has to be removed.Do the Scat Packs have the round snorkel from the headlight vent? That seems to be the only difference. Mine is buried in the garage, so I can't check right now.
Will do! I'll put the airbox in first and then when it warms up, I'll do the snorkel tube.Nice
I was thinking of doing the same however they say you need to take the front fascia off to install the snorkel
Let’s us know how much of a pia it was to install
No, it is a direct factory replacement. you probably need to make sure it is aligned properly.Did yours fit without any issues? I bought the Mahle. My issue link below.
Dumb ?? Scat Pack air filter box front screws??
I replaced the Oem air flter with the Mahle.. Why ? I was bored. When I put the cover back on, there is a gap between the top and bottom of the airbox where you place the 2 screws in the front. The right side screw mount looks like its flush. I wasn't sure if should be flush, so I didn't screw...www.chargerforums.com
My friend is from Utah, showed me pics of brown snow. Did you also experience this?.Hey All. Just installed a 68172459AA (6.2 Hellcat Air Filter). I will update my thoughts later since it is snowy here in Utah, but I took Bianca out for a spin and I "think" I feel a difference. haha
On order is the HC lower box and snorkel.
Cheers!
Yes, it was NASTY!My friend is from Utah, showed me pics of brown snow. Did you also experience this?.
Sorry for my lack of knowledge but the HC air filter and lower air box is intended to ..lower the air intake temp? What difference are you feeling?
Yes, it was NASTY!
The filter just increase the CFMs. The HC airbox should help lower the iat. Right now, with just the filter change, I notice much better throttle response.
fo sho!Especially with that ram air duct from the front.
I find my IATs are pretty low already.Yes, it was NASTY!
Lol.I find my IATs are pretty low already.![]()
I am in Ottawa and this is the mildest winter I can remember in years. We have had only about 10 days below -20, and most days are around -10. this is awesome.Ugh I hear that...odd that the states are getting walloped more than us at the moment but, still it's been an annoying...what? Month? Of -10+ Celsius
