Cool... but, I was hoping to tap under the dash based on my location preference.From a fellow forum member
http://home.nc.rr.com/maneval69/overheadpower/overheadpower.htm
How do I get the pillar cover off? Do the top console wires run up it? If so it sounds like the Pink or Pink/green will be there! That would be way cool!Right side "A" pillar, baby! There's no need to go spelunking in your dash...
Yep, same here, with 8" Invisicord!I hooked mine to my UConnect rear view mirror.
I just ordered my Invisicord. Did you have to remove the mirror to do that or not?Yep, same here, with 8" Invisicord!
I thought about buying the invisicord, but I like the mute button on the cig. lighter power cord. Is there any solution to this with invisicord?
Does anyone know if the wires are the same (pink for accessory and Green/White for the negative) even if the rearview mirror is the traditional one and not the blue-tooth automatically dimming mirror?FYI:
I found this if anyone wants to wire from the top... GREAT write up!!!
http://m3coupe.com/Charger/Valentine/V1_Install_v2.doc
There is NO wiring to cut or any mirror removal. This is one of the simplest things, and some seem to make it much more difficult. The invisicord plugs right into the back of the factory mirror plug. That's it. And you have on/off with ignition as well.I just ordered my Invisicord. Did you have to remove the mirror to do that or not?
Yeah that post is 10 months old. I have had the invisicord installed for awhile now and I am very pleased.There is NO wiring to cut or any mirror removal. This is one of the simplest things, and some seem to make it much more difficult. The invisicord plugs right into the back of the factory mirror plug. That's it. And you have on/off with ignition as well.
I used one of these mounts for my Bel and it is rock solid, no bouncing over bumps, and it's been on for two years......detector comes off in a second if you want, but I leave mine up all the time.
http://www.countryjoycrafts.com/350Z/valentinemount.htm
I spent some more time looking for an accessory wire in the map light area to no avail. Has anyone been able to hard-wire in a 2008?In my 2008 the pink wire with green stipe does not appear to be an accessory wire (mine does not have any power in the off or accessory position) The red wire with the green stripe has constant power.
I used the red wire with green stripe for now, but I am hoping that someone might have an answer as to how to get the pink wire with green stripe to have power. Is there a fuse that is not inserted in cars that do not have blue tooth or auto dimming mirror?
