HALF PRICE SALE * Chrysler 300C / Magnum / Charger / Challenger / POLICE Suspension Maintenance HALF PRICE SALE
As the miles accumulate on your LX chassis your springs and shocks wear. Suspension wear is an insidious form of wear because it is incremental occurring over every inch you drive. It is hard to notice because it creeps up on you -- one inch at a time. Once you have gone past 40,000 miles you are on the backside of your Original Equipment shocks and struts performance curve. You know you need to do the maintenance work, but who wants to spend money in this economy on maintenance that can wait another week or month or... While you are waiting you are putting more wear and tear on your front end ball joints because of all the excess bouncing around due to damper wear. Your tires are wearing because the struts, shocks and ball joints are wearing. Your tension rod bushes are wearing or tearing because of the ball joint, strut and shock wear. While all that is going on your springs are losing their spring too. Maybe if a leader in LX suspension had a HALF PRICE SALE?
Pedders USA has a solution. For a limited time you can buy Pedders LX Suspension Maintenance Kit for ONLY $412.41 That includes 4 Precision made Pedders SportsRyder Coils and 4 Gas SportsRyder Dampers
LX Suspension Maintenance Kit for ONLY $412.41 HALF PRICE!!!!
Front Coil (2) 7940
Rear Coil (2) 7981
Front Strut (2) 144304
Rear Shock (2) 141206
This sale ends when we reach our inventory balance goal for the LX which is a LIMITED NUMBER. I can GUARANTEE you will never be able to buy Pedders coils and dampers for your LX at a lower price. You save $412.41 on the highest quality dampers and coils available for your LX based Charger, Challenger, Charger or Magnum.
Charger Base Front 720mm Rear 720mm
Charger R/T Front 707 Rear 707mm
Charger SRT8 Front OE 692mm Rear 680mm
Charger Pedders Maintenance Kit Front 692mm Rear 697mm
300 Base Front 720mm Rear 720mm
300C Front 707 Rear 707mm
300 SRT8 Front 710mm Rear 580mm
300 Pedders Maintenance Kit Front 692 Rear 700mm
Magnum Base Front 711mm Rear 711mm
Magnum RT Front 702mm Rear 705mm
Magnum SRT8 Front 683mm Rear 705mm
Magnum Pedders Maintenance Kit Front 692 Rear 695mm
Challenger SRT8 Front 686mm Rear 697mm
Challenger Pedders Maintenance Kit Front 683 Rear 687mm
While you are doing your Suspension Maintenance you may want to add these Critical Components
EP1172 Sub-Frame replacement Bushes
EP2113 Bumpsteer Corection Kit $84.00
EP6567 LX Front Radius / Tension Bush Replacement Kit
EP6570 Front Camber and castor Adjustment Bushes
EP7277 Rear Camber Kit
LX Dampers ONLY $249.00 SAVE $205.63
Want only new dampers because you already have Pedders lowering coils. No Problem. $249.99 for a limited time. SAVE $205.63
Front Struts (2) 144304
Rear Shocks (2) 141206
INSTALLATION by SPECIALIST!
Your local Pedders Suspension Specialist can answer all your questions about the LX chassis and suspension maintenance. A 28 Point Inspection invites YOU to actively participate in your suspension evaluation from ride height measurements to bush inspection. The LX chassis is a complex system that requires a bit of TLC to run as well at 100K as it did off the showroom floor. You Pedders Suspension Specialist is uniquely equipped to cost effectively service your LX suspension with tools you Chrysler / Dodge Dealer doesn't have. You can find your Pedders Suspension Specialist on the Pedders USA Dealer Finder.
NOTES: This special pricing is NOT available with any other kits. There are NO substitutions. Quantities are limited to existing inventory. Sales ends upon posted notice.
Front Coil (2) 7940
Rear Coil (2) 7981
