Me too! Going to get the rear calipers in spring. I’ve dropped a lot of coin for my car recently and haven’t even started Xmas shopping.
I know the feeling, $6k supercharger put a hurt on the wallet lolMe too! Going to get the rear calipers in spring. I’ve dropped a lot of coin for my car recently and haven’t even started Xmas shopping.
"Green Fade" happens when you bed in a set of new brake pads.. lots of repeated stops from 40- to 5 mph to get them hot enough stink like Sasquatch and the car doesn't want to stop. It is done to properly "cure" the new pads by burning off the excess gases released by the binding goop that holds them together. Properly bedded pads stop great, improperly bedded pads don't stop worth a damn.What’s green fade exactly mean? Lol. I’m retarded.
A set of Performance Friction Carbon-Metallic pads will cure that problem- the pad material goes all the way to the edge, it is not cut off 1/4" short like all the other padsDid the same upgrade on a 2017 SXT Rallye AWD. Using the powerstop bedding procedure wasn't enough. Had to do more aggressive braking from 100kmph to 5.
Also the rear pads don't cover either edge of the rotors, so you can see untouched portions on both top and bottom.
Will get these next time when it's time to replace.A set of Performance Friction Carbon-Metallic pads will cure that problem- the pad material goes all the way to the edge, it is not cut off 1/4" short like all the other pads
Check the splash guard- it is very easy to bend them by accident. If they rub on the rotor they will make that weird screech.Have a weird screech in the front tires though at low speeds, like something metal is slightly rubbing against something.
Will check this weekend.
