Hey guys I wanted to make an install guide for those who are interested.
This was done on a 2017 Charger SXT AWD RALLYE but should work on any AWD that has BR5.
I bought new brake shields (68217407AA & 68217406AA) and SS brake lines (950.63003) but sadly they did not fit.
Brake shields are too large (and you have to drill new holes for them): https://i.imgur.com/F1PGXpr.jpg, https://i.imgur.com/IYEGYuA.jpg, https://i.imgur.com/SMUEObM.jpg
SS Brake lines are too long.
Parts List:
These reman calipers are hard to find, when in stock they sell quick, rockauto.com & stevewhiteparts.com is where I ended up buying my components. I have fixed everybody's inventory on these calipers in the last couple of months because I tried to order them and they actually did not have them in stock :crying:
Front:
Left Caliper: 18-B5496 | A1 CARDONE
Right Caliper: 18-B5497 | A1 CARDONE
Rotors: 781774PER | RAYBESTOS (370MM / 14.6in)
Brake Pads: Z371767 | Top Cop by Power Stop (1767)
Rear:
Left Caliper: 18-B5510 | A1 CARDONE
Right Caliper: 18-B5511 | A1 CARDONE
Rotors: 780395PER | RAYBESTOS (350mm / 13.8in)
Brake Pads: Z371766 | Top Cop by Power Stop (1766)
Rear Brake Swap:
Parts List:
Front:
Rear:
Front Brake Swap:First things first, jack the car up and take off the front and rear wheels.
Remove the two bolts that are holding the old caliper in place (rotor is removed already for clarity)
Slide the old caliper assembly off of the rotor and set the caliper assembly on the A Arm until you get the new caliper assembly installed (you can see where I am talking about in the first image)
Pull off the old rotor, and install your new rotor
Take your new caliper bracket with the new caliper carrier removed and install the brake hardware
Install the new caliper bracket using the 2 bolts you removed off of your old caliper bracket
Install the brake pads onto your new caliper bracket that you mounted
Install the new caliper carrier onto the new caliper bracket, ensuring the slide is angled to catch the metal notch when you tighten it
Remove the OE brake line from the old caliper carrier, and install it with new copper gaskets (top and bottom) onto the new caliper carrier (picture is from the rear caliper carrier, its the same procedure)
Rear Brake Swap:
Remove the old caliper assembly by removing these 2 bolts (it might be easier to remove the old caliper carrier from the old caliper bracket before you remove the 2 mounting bolts)
Remove the old rotor by yanking evenly on both sides (on the 2nd old rotor I had to use a pry bar in order to get it off the parking brake shoe)
Install the new rotor by lining it up and applying even force (both hands slamming) on both sides to get it onto the parking brake shoe
Install the brake hardware onto the new caliper bracket
Install the brake pads onto the new caliper bracket
Slide the bracket over the new rotor and attach it with the 2 bolts that were removed from the old caliper bracket
Install the new caliper carrier onto the new caliper bracket, ensuring the slide is angled to catch the metal notch when you tighten it (picture is from the front caliper, its the same procedure)
Remove the brake line from the old caliper carrier and install it onto the new caliper carrier with new copper gaskets (top and bottom)
Bleed the brake system (beyond the scope of this guide)
Install wheels
