would drilling a tiny hole in the bottomof the plastic cover help ?
Drill the hole,dry them out and then seal everything up with silicone. By everything I mean the drilled hole and create an extra seal around the inside of the light where it separates. Something isn't tight but the silicone is weatherproof and will solve your problem. If you want to dry it fast after you have the hole, kick on your high beams. You could also just send them back and complain.
i emailed where i got them from so im waiting on that and i can what they say. odd thing tho. they only get condensation when i drive, if im not driving there is none.
