I was giving it as much gas as I could with out spinning on the start line. The rpm holds at about 2200 rpm unless it spins. I was noticing that the car has a slight bog or hesitation when I go from about 80% throttle to 100%. I am assuming this is the computer changing to WOT programming but that's just a guess. The best time was run by holding the gas pedal at about 75% and flooring it before I released the brake to launch.BSUfanatic said:I also forgot to ask what rpm did you launch at? Was traction on/off? Did you leave car in drive or put in first gear and let it shift itself or did you shift manually?
My car had 523 mile on it when I got to the track.AZCHARGER said:I`ll be going to the track once my car breaks-in!
DAM TROLLS! lol!Don't abuse it now....
Mike
Tell him to call "Grey" if he wants the gauge cluster....4DRHTRD said:Yup Troy is an awesome guy.
Mike
Excellent, very helpful, posts, maneval.maneval69 said:I left the car in 1st gear and let it shift.
I turned traction control OFF (accept once and it activated cost about 2 tenths)
Thanks,Meister said:What tire pressure were you running, maneval? 22-24psi, rear, and pretty high in the fronts may be a good starting place.
