Yea,
They are definitely more noisy than my Eagle LS tires on my 300M. However, the LS tires I have on the M are H rated so 130 mph top speed for 7.25 hours sustained.
Your F1 tires will say 245/45 ZR 20 Y99 in the front and 255/45 ZR 20 Y101.
This means that the tire is Z rated for over 150 mph sustained + the Y tells you something else.
W = up to 168 mph but not exceeeding
X = between 168 and 186 mph but not exceeding
Y = in excess of 186 mph sustained.
99 = load rating
101 = more load capacity than 99
So yea it will be a little harder and noiser but designed for when and if you ever get to the autobahn you will not have to worry about the tires failing from sheer speed.:clap:
Thanks
Brian
BND Automotive LLC:bigthumb:
440-821-9040
