How do you get the rings around the gauge cluster off, I've noticed the outside rings are easy to pop off but I'm afraid to move into the inner rings for fear of breaking the thin plastic. Any tips...Thanks in advance.
When I did mine, I used 2 butterknives. I got the outer ring on one side lose and used one butterknife to keep it free. Then, using the other butterknife, I carefully pried the center section out. When you get the knife between the rings and the dash, you can slide it over until you fell it hit the clips. If you pry next to the clips, you'll have less of a chance of breaking the rings.
