I just pulled the fuses and did what the post said, yes I did pull the correct fuses, with the fuses out the car started according to the post the car should not start.
Any suggestions? I have an 2006 daytona. There was no 16 fuse
Did you pull from the correct set of fuses. You have some in the trunk and under the hood. Sorry, but I had to ask. If you pulled the fuses under the hood and your car started, then I'm puzzled.
Im pretty sure he pulled the trunk fuses, On my last R/T thats what I did like 4 times thinking I was doing it right lol, and there was never a fuse 16 there
If i remember correctly there is not a 16 fuse if you're reading the engine fuse box backwards. It is a mirror image. Took me a few minutes to figure it out myself.
1 - 6 of 6 Posts
