1 - 17 of 17 Posts
I noticed a strong gas smell in and around the car several weeks ago after filling up but I did not overfill or spill gas anywhere. After having a mechanic diagnose the issue he found that the fuel pump under the rear seat on the right side was leaking and had fuel pooling up at the top.
As first step he replaced the O-Ring seal on the fuel up. After replacing the seal there was no leak initially but it occurred again after the next fill up. So it seems the leak only occurs when the gas tank is full. Since the seal was already replaced but the leak is still there I took it to the Dodge dealer who will have to diagnose it further but they told me that it is most likely the gas tank that is leaking and they have seen many problems like this already and I am not the first one.
What should I expect as far as the diagnosis and how much should I expect to pay for the repairs?
I have the same issue with my 2011 Dodge Charger SE RWD, Dealer informed me it would cost $2,070 to replace tank, which is crazy since I only have 77,000 miles on call NHTSA, National Highway Traffic Safety Administration, (888)327-4236 and file a complaint, (safercar.gov) and they will investigate, they will force Dodge to do a recall, Dodge is aware of a defect in the design of those gas tanks, they have since changed the design, they will have to fix our vehicle or refund any money we spent on repairs.
I have a 2011 Dodge Charger Rallye. I bought it new. I had a very strong gas smell in my garage and eventually inside my car. I had it towed to the dealership last Thursday due to concerns of fire or explosion. They diagnosed that my secondary fuel pump was leaking under my rear seat due to a crack on top of the fuel pump. When I inquired what could cause the crack, he had no answer except it is plastic and might have gotten brittle over time. The car isn't quite 7 years old, and it's garage kept in South Carolina. I'm reading all sorts of similar complaints online. My dealership says there's no recall to date. It sure looks like there ought to be. I have never had a fuel pump leak on a car, and I had a Buick to 185,000 miles and a Chrysler to 160,000 miles. Did you get anywhere with NTHSA?
Hi Carolina Dodgegirl,
We appreciate you taking the time to bring this to our attention. We would be more than happy to look into this further and offer our support while you are working with your dealership. Please feel free to send us a private message with your VIN and additional details if this is something that interests you.
Julie
Dodge Social Care Specialist
Carolina Dodgegirl:
Do you know if there is rust on the pump retainer ring. The Gen 2 Durangos have an issue where the retaining ring rusts, and then the expansion caused by the rusting metal cracks the FP housing. So far, the result has been an Evap leak and a P0456 code. I am not aware of any fuel leaks because of this issue.
Either way the problem is the result of cheap parts, and should not be as such for a vehicle in any price class. Fuel systems are not the place to be cheap.
Don
I am just now getting back to this forum. I don't know if the ring was rusted. I'm guessing not, because they didn't mention anything about that. However, I am extremely frustrated. They replaced both fuel pumps, but gave the car back to me wreaking of gas inside! I had it detailed this past weekend, $160 later it still wreaks like gas! There was a piece of material, looks like of like the padding under carpet with plastic on top between the fuel pumps and the seat. It wreaked! So I had my detailer cut that piece out, hoping that would take care of it. It did not! I am wondering if the gas saturated my back seat. They steam shampooed it. This is all so unsafe! I can't believe they're approved to manufacture a car where the fuel pumps are inside the car like this!
Thank you for your reply. I did not have time last week to get back on this forum. The dealership replaced the fuel pumps, but they returned my car to me still wreaking of gas. The service manager basically told me it would just eventually go away. The material over the fuel pumps wreaked. I had my detailer cut it out. He said the smell would never come out of that material. I am wondering if my seat was saturated with gas. This is all totally unacceptable to me and horribly unsafe!
I would definitely appreciate Dodge's help. I'm not sure how to send a private message on here to give you my VIN.
You can send us private message by clicking on you username on the left side of this post. You will then see a small drop down list. Click on "Send a private message to DodgeCares."
Julie
I'm going to piggy back on this post, I hope that's ok.
I have this same issue on my 2011 Dodge Charger. It's been going on for quite a while now. Years, in fact. Yesterday I came out of the store - had been there for less than an hour - and you could see the large puddle under the back passenger door. My husband and I watched it for a while and the drips were long and fairly steady. It's scary and I have waited too long to take action, but I have to do something now. I would also appreciate any help Dodge could offer.
Thanks in advance.
Has anyone had this problem solved yet? My 2011 R/T has smelled of gas for the past couple of weeks and yesterday leaving my driveway, left a trail of gas out and back into my driveway. I cant even sit in my car without all the windows down and I have the same puddle underneath the rear passenger side
Ben:
Welcome to the forum. as far as I know, there has been no recall or other type of program to address this issue. If you are so inclined, there are access covers for the pumps underneath the rear seat bottom. You can remove them and see if you can observe any problem. In any case, I would not continue to drive a car with such an issue. It could be deadly. If you happen to park in your garage, and have a gas furnace or water heater in there, that could be a recipe for disaster.
Don
Reactions: BenG87
Hey @BenG87 - I just had a chance to respond to your PM on this!
Mark
DodgeCares
I have a 2010 sxt, I got a p0456 code on dash so naturally replaced gas cap and reset code, code did not come on until I filled up with gas, same code. Now I realized I have a gas leak by passenger rear door, so I popped the seat off and fuel pump cover off on the passenger side and also found a puddle of gas on top. Will replacing this passenger side pump fix that leak?? If so can I just replace that fuel pump or do I have to replace both??? I don’t know if there is a recall on this but even if there is I’m unsure if I can use it because I am 2nd owner and it has rebuilt title.
I have the same problem, replaced with 2 new pumps still same leak
Hi LilMason3,
If you decide to address this concern with your certified Dodge dealer, please feel free to send us a private message. We are happy to help with that process.
Rob
Dodge Cares
Hi LilMason3,
Rob
Dodge Cares
Hi LilMason3,
Rob
Dodge Cares
I've been having the same problem thought it was my fuel filler neck since it only happens when I pump gas. Checked it looks good. Checked under the seat secondary pump passenger rear good no leaks. But primary pump rear divers side the plastic black cover cracked removed sure enough gas leak on top of pump. Nice pool of it. I read this is an issue why is there no recall!!!. So what happed is the pressure from sitting in the back seat smashed on the black plastic cover which then smashes the the connector causing damage to the fuel pump which cracks and causes a leak. Such a stupid design. I can do this repair myself but this 2013 Dodge charger v6 has had more problems then I could count.
1 - 17 of 17 Posts
