1 - 4 of 4 Posts
5.7 Hemi, I cannot find it anywhere in the service manual. I do not think these models have a serviceable filter. The only place I can think of now is, that it is located within the fuel pump, which is located under the rear seats.
Can anyone confirm this about the fuel filter, as in "there isn't one"?
It is under the back seat, pull the seats and there is an access panel in the tank to pull the pump.
yea most dodges dont have fuel filters other than the pump one
there is no fuel filter. there is only a fuel sock. thats another reason why you never want your fuel to run below 1/8 of a tank-not only can you pick up crap off the tank bottom but you can also burn up the pump. the pump use's the fuel in the tank to cool itself. i had my pump out for replacement 3 weeks ago because the girl friend likes to run it on fumes and burned the pump up and there is no filter and after 14000 miles the sock was full of crap from the tank bottom.
1 - 4 of 4 Posts
