Well, tonight dropped and inch of snow, and it seemed to be the perfect time to practice some snow recovery maneuvers. (Being 18 and very foolish)
The vehicle is a 2014 Dodge Charger R/T AWD
I found out that the AWD system is rear biased.
I hit a curb sideways at 3-5 mph, and a couple things resulted.
1. I believe the drivers side steering shaft snapped inside the rack and pinion assembly. It is loose, and able to come completely out of the assembly.
2. "Service AWD system" appeared on the EVIC. It goes straight to RWD.
Well, I checked the passenger side steering, and it works fine.
The engine runs fine, and the car can go forward.
I was wondering what part this is called, so I could buy it, and go to the dealership with it ready ahead of time, to make this problem be resolved as smooth and orderly as possible.
Is there anything else that you guys would do after this, other then setting up and appointment with your dealer to get it serviced, and getting a flatbed to get it there?
What is this broken part called?
Is there anything else you would recommend I look at?
Is there a place you guys recommend to find/buy parts?
Is there anything I'm forgetting with a problem like this?
Any recommendations and suggestions are highly valued,
Thank You
Thank You
