I was wondering what year they went to that....50 ft-lbs
I have a '12 and it has the older spindle style with the single giant retaining nut. I knew they switched it up during the 13-14 run I just didn't know what year lol.I think they changed to the three bolt design in 2013.
How'd the rest of the surrounding suspension look/feel? Brakes?Welp, that didn’t fix the noise. I mean the hub was bad but still sounds like a belt squeal. My ex gfs dad is a mechanic and he thought it was the hub. He changed the water pump and new belt few months ago. Still have a noise though![]()
Did you know the torque specs of the axle nut?Yeah....you're gonna have to drop the diff to get the axle out of it. Logically you should be able to just pull the spindle, but the PITA it was to pull and install a rear spindle without an axle or hub in the way leads me to believe it is not really a viable option.
Almost everything on the car has a torque spec lol.Thank you. Do the 4 hub e torx bolts have a torque spec?
Ruh roh. Maybe it's a tire out of balance? I have something similar going on right now.Well I changed the rear hub without having to remove the cv axle but the noise still there.
