Both my fob's are broke. One is taped up and i can still drive the car but the housing on the other cracked and a small part is missing...if i buy an extra fob online is there an easier (cheaper) way to program it versus going to dealer??
Yes, but you need to keep both keys. Check the owners manual for an in depth step by step programming, but basically you put the first key in,turn , then the second key,turn, then the new key, turn.
Are the circuit boards inside the keys broken?
If not I'd wonder if you can't just find some used keys for cheap, and swap over the internals? No programming required for that.
awesome...thanks...no the circuits arent shattered....its just the casing...i noticed on eboy i can buy the fob for like 38.00 but ill try to reprogram myself
There are many options buy new fob, buy the complete key, buy the keywith chip but no control, just whatever suits you. You can switch the circuit board over to a new casing.
