1 - 8 of 8 Posts
I was installing my new flashpaq today and got text that said
Tuner Status:
Locked program w/error
It then went to recovery mode and after first recovery attempt it said-
Locked Recovery Mode
Then it just keeps going thru the same process over and over. My check engine light also came on.
Could it be because of the NOESP.com mod I did a few days ago?
Any help would be great. Thanks
I am not quite sure I understand your problem. Are you saying as soon as you hook up the flashpaq, then you get
Tuner Status:
Did you actually ever go through the whole process of installing the tune on your car, or did you get an error before you could? Did you buy the tuner new? Are you sure it is part #3825?
did you buy it used? if so, the previous owner probably didnt reset his car to stock tune, thusly leaving the tuner locked to his car.
X2........The "lock" code indicates it's locked to the previouse owners vin info.
Need to take it back to them, have them plug it in and reset their car back to the stock settings, once done it will be unlocked for you to use.
When SC starts up, doesn't it show the vin that is programed? All you have to do is plug it in, and when it comes on, look and the vin and see if it is yours.
I think someone got played, oh no!! I seriously doubt the guy that sold it to u is gona A.) return your money or B.) return his sytem to stock. Imean why would anyone dude, hes enjoying the benifits of it basically for free.
Your only recourse is to warn as many people as u can of this scam so that no one else falls victem to this type of thing.
1 - 8 of 8 Posts
