Does anyone know the outside diameter of a stock 2013 rt exhaust pipes? Just ordered my spintec and I doubt they are three inches so I need to buy some adapters for welding
I know I am new here, but this does not make sense. Did you mean 2.5" OD adapters will fit "inside" 2.5" ID pipe ? Because you can not take something with the OD being the same size as the ID and make the OD piece "fit over" the ID piece, you have metal (however thick it is) on both pieces going in opposite directions.Your adapters will need to be 2.5 OD to fit over 2.5 ID. Very simple as you said.
Post a vid, I will listen for sure.The pipes from the x pipe back are actually 2 1/4 I measured them but I'm upgrading to 2 1/2 with spintec mufflers tomorrow should sound pretty bad ass. And the adapters can be flared any way @bake74 I'm welding all of it. Ill post a vid if you guys wanna hear it?
Thanks for clearing that up for me.I do all my own exhaust work. What I'm saying is they measure the adapter like this 2.5 OD and 2.5id. That meaning one side will fit over 2.5 ID tubing and the other side would but flush to 2.5ID tubing. Meaning if you need a adapter and it need to fit over 2.5ID the adapter need to be 2.5OD. Just finished my exhaust today. Here's a few pics a videos so you can see how I used adapters to go from. 2.5OD to 3OD and then back down from 3 to 2.5. Click on last pic to see video.
I have a video PM me your email if any of you guys wanna hear it.Lol so glad you have a sense of humor, that lacks in a ton of members here!! Cool ill have to look them up myself and as for resonated tips. The have a perforated center and packed w/ a fiberglass like material to knock of some DBS under part throttle. Under WOT conditions they act like any other tip. You should be able to tell the difference between the two videos I posted. They also help produce a deeper tone.
