There is a section in your owner's manual under "tire rotation" that gives a decent description of the TPM system. It should learn the new wheel locations after the rotation.I'd like to rotate my wheels, but I'm concerned that there is some hidden surprise I'm going to find related to the fact that the EVIC knows my tire pressure(s).
Anyone know how that works?
The SRT tells the tire pressure for each wheel. The R/T just shows a signal if one of your tires is low.I don't know if it actually know the location of each wheel, if it did, why can't it tell us which tire is low? My other vehicle has a picture on the dash showing exactly which tire is need attention.
There is a BASE system that is in most cars that only signals when any tire is low without any more detail. The PREMIUM system shows actual tire pressures and can tell which one is low. As mentioned, its on the SRT Dodges and most 300C's. This info is also in the owner's manual.I don't know if it actually know the location of each wheel, if it did, why can't it tell us which tire is low? My other vehicle has a picture on the dash showing exactly which tire is need attention.
Just grab a 1 or 2 ft piece of 2x6 lumber and drive on it. It should give you enough clearance to get the jack under.Well, my effort for this weekend was thwarted by the fact that my floor jack won't fit underneath the car.
Waaaa!
Ahhh, yes grasshopper. The 2x6 lumber technique. Practice to become expert. Drive on, drive off. You too will become master like Sensei.Just grab a 1 or 2 ft piece of 2x6 lumber and drive on it. It should give you enough clearance to get the jack under.
Thanks for the info. I didn't know that.There is a BASE system that is in most cars that only signals when any tire is low without any more detail. The PREMIUM system shows actual tire pressures and can tell which one is low. As mentioned, its on the SRT Dodges and most 300C's. This info is also in the owner's manual.
