OK went to the RT and pulled up the diagnostic mode. What exactly do these mean:
1) VTA trig: NONE
WAKE: LF DOOR
>198 Lgt:237 (note that the arrow and 198 can be changed by pressing the arrow button on the steering wheel. What does this do?
HBduty: 0%
2) Last Chime Req :abs
VMM 419
3) MinL = 191 MinR = 200
LT=44 Rt=6
(note that the LT and RT move under accelerationL LT goes up and RT down)
19g Avg=49
Hope someone can explain these especially the >198 as it was 196 and I pressed the arrow button twice.
Thanks in advsance
1)VTA trig -vehicle theft alarm- The none shows it has not been triggered by anything , say like opening the door. The rest of that no idea
2)Last chime is what caused the car to make a chime sound , it was your ABS
3)This shows fuel levels in your tank , as its a saddle tank you have two sides and its showing the two levels .
1) VTA trig: NONE
WAKE: LF DOOR
HBduty: 0%
VMM 419
LT=44 Rt=6
19g Avg=49
Thanks in advsance
Yep, you were playing with the headlight auto-on sensor. I moved mine to a higher number so it wouldn't come on when just going under a short tunnel. Now it has to be getting truely dark for mine to come on. I like that a lot better.
EVIC Code List
Is there a list of EVIC codes and/or functions?
Who guards this secret?
1) VTA trig: NONE
WAKE: LF DOOR
HBduty: 0%
VMM 419
LT=44 Rt=6
19g Avg=49
Thanks in advsance
