Same logic with people who want to spend gobbs of money to upgrade and supercharge the 392 instead of just using the money to buy a hellcat with warranty lol going to spend more then it's worth just to bring it up to par with something you can buy without the headache and hassleI love how no one researches BEFORE they spend the money anymore LMAO, always after. Yes you can do it. Yes it will bolt in to the car and the trans. No your weak open rear diff won't like it. Neither will your instantly substandard brakes. You will need 09 5.7 PCM with the 6.4 tune flashed into it and harness to use that PCM (has to have VVT). If you intend to use the active intake manifold then you'll need an rpm switch. If you're doing this yourself (which I doubt) then Hotwireauto can hook you up with PCM & harness work. Be prepared to shell out some $$. If you aren't doing this work yourself then be prepared to shell out even more $$ for a shop to do it.
Not even remotely true. I have WELL above demon power for quite a bit less $$ than a new Hellcat with decent options and have options unavailable on either of the "upper trims" and have the power train to back up waaaay more power later on.Same logic with people who want to spend gobbs of money to upgrade and supercharge the 392 instead of just using the money to buy a hellcat with warranty lol going to spend more then it's worth just to bring it up to par with something you can buy without the headache and hassle
Interesting what year is your charger? and how much did you spend? Im saying modern 392's that spend thousands to replicate hellcat power is what i meant if im not mistaken stock 392's can only handle so much power then you have to start essentially replacing entire components just to handle more power especially if running boost and such at that point might aswell get something with warranty if something breaksNot even remotely true. I have WELL above demon power for quite a bit less $$ than a new Hellcat with decent options and have options unavailable on either of the "upper trims" and have the power train to back up waaaay more power later on.
I have a '17 Scat Pack. The only things I don't have are 6 piston brakes and adaptive suspension.Interesting what year is your charger? and how much did you spend? Im saying modern 392's that spend thousands to replicate hellcat power is what i meant if im not mistaken stock 392's can only handle so much power then you have to start essentially replacing entire components just to handle more power especially if running boost and such at that point might aswell get something with warranty if something breaks
Gotcha apologize for the ignorance on that topic I don't know much just what Im told by other owners very interesting information you bring up maybe when my warranty is up I might modify my scat theres a really cool shop here in Tampa called 1320 motorsports that does Pro charging and etc etcI have a '17 Scat Pack. The only things I don't have are 6 piston brakes and adaptive suspension.
After building 30+ hot rods I was finally at the point in my life that I could pay someone to build one for me. I talked to several builders, settled on one, dropped my car off and picked it up when it was done. I got a 1yr/ 30k mile warranty on it (although warranties aren't my worry) and drove away with 850rwhp and all factory options functioning. It's also set up to pulley down the f1a94, retune and add e85 to make closer to 1200rwhp and everything is there and built to hold that.
I spent roughly $36k on the build. I already had the car, which I paid (I think) $34 or $35k on brand new. It had 20k miles on it ans a year of factory warranty left on it when I dropped it off.
A new Hellcat (which won't come with some options like ACC) is at a minimum $80k (and that's being generous). To make the power I make now on pump gas, you'd easily dump another $8k-$10k into it and then hope the rear diff didn't grenade on the first launch with drag radials on lol.
Whatever you do, make sure they do Mopars....and lots of them. Chevy and Ford builders/ tuners can and will FUBAR a Mopar in no time flat.Gotcha apologize for the ignorance on that topic I don't know much just what Im told by other owners very interesting information you bring up maybe when my warranty is up I might modify my scat theres a really cool shop here in Tampa called 1320 motorsports that does Pro charging and etc etc
Easier yes, as it is a non-VVT engine as well. Uses the same accessories. Stroker based on your 5.7 block is even easier; the only changes are internal. Cheaper not necessarily, 6.1's are getting scarcer (they were only in production for 6 model years) and a quality 5.7 stroker short or long block (plus labor if you can't do it yourself) isn't exactly pocket change. 6.4's on the other hand have been in production for going on 13 model years now in both SRT and truck flavors. The truck 6.4's are already getting cheaper and they have a good foundation to start with, just change cam and intake.Don’t mean to hijack, have a question. On a pre vvt car is the 6.1 swap possibly easier and cheaper than any 6.4? Or having a stroked 5.7 built?
As another option.
