If that is your issue, and you catch it early enough, yes. You will want to look into it a bit further tho, so you know that is the issue. The lifters are not cheap, and since the heads must some off, labor, unless you can DIY, and be quite a shock. Folks who need a cam and lifters, are paying $3.5-$4k for this repair. It may be just a failing solenoid. They are ~$80,. The intake must come off to access them.
Don
