1 - 2 of 2 Posts
Hello, recently my 2018 charger @ 56,xxx miles started showing weird signs where the EVIC would shut off for a few seconds(needles would still work) Headlights and interior lights would flicker, and the passenger would roll down randomly, especially at a high rpm.
The EVIC shows the battery voltage fluctuation rapidly between 13.2 -14.1, when it occurs.
I figured it was a bad Alternator, so I replaced it with a 180 AMP. It appears the issue is less frequent now, with only the Voltage fluctuation and EVIC shutting off.
My next choice is to replace the Battery. (Under autozone warranty)
Any ideas on what may cause it?
What happened to the OEM battery? Odd to have an autozone battery in a 2 year old car.
Have you made any electrical modifications from stock? Non oem accessories?
1 - 2 of 2 Posts
