Starts in Great Britain, Stops All Over The World
EBC Brakes are proud to become a Vendor for the Charger community. We are here to assist with any brake questions or application issues, generally anything brake related so let us know how We can help.
EBC Brakes’ Range of High-Performance Automotive Braking Products
When it comes to performance aftermarket braking components, there aren’t many names that are embedded as deeply into the scene as EBC Brakes.
EBC Brakes is an independently owned and managed brake manufacturer, employing over 400 people across the UK and US, and produces the world’s largest range of brake pads and discs for virtually anything with wheels.
Supplying some of the best-selling ranges of brake discs and pads for the majority of cars, EBC Brakes is a solid choice when it comes to improving your Charger’s stopping power.
Below is an overview of some of the key braking components we supply.
BRAKE PADS
EBC Brakes Ultimax Pads
OEM-Replacement Pads
  • Factory-replacement pads offering improved stopping power at a lower price point
  • Superb daily driver capabilities
  • Work well in all climates
  • Feature ‘brake-in’ surface coating for instant, safe braking after install
  • Ideal for: daily road driving
EBC Brakes Redstuff Pads
Ceramic Low-Dust Pads
  • EBC’s ceramic formula designed to keep dust levels to a minimum
  • Up to 15% braking improvement for road driving
  • Minimal disc damage characteristics
  • Ideal for: prestige and high-performance road cars
EBC Brakes Yellowstuff Pads
Ultimate Street Pads
  • EBC’s flagship fast road and light track pad for all higher-powered cars and SUVs
  • Excellent cold bite and high temperature fade resistance
  • Drastically reduced stopping distances compared to OE equivalents
  • Progressive braking with unparalleled pedal feel
  • Ideal for: fast street driving and occasional track days
EBC Brakes Bluestuff NDX
Fast Street/Endurance Track Pads
  • Fastest street, endurance race and track material with highest friction from cold
  • Road legal for some European markets which require ‘NDX’ suffix road legal pads, but all other markets can use Bluestuff on road with excellent results, since unlike most race materials, this formulation has fantastic bite from cold
  • Surface scorched to eliminate ‘green fade’ and reduce bed-in time
  • Ideal for: fast street driving, track days and endurance racing
BRAKE DISCS
EBC Brakes Premium Brake Discs
OEM-Replacement Sports Discs
  • Acclaimed range of high-performance solid, grooved and drilled brake discs
  • The perfect way to complement EBC’s high-performance pads in your vehicle’s factory-caliper brake setup
  • Ideal for: spirited road and occasional track use
EBC BRAKES RACING COMPONENTS
Formed in 2015 as a response to the ever-expanding track day and race car markets, EBC Brakes Racing is a sub-division of world-leader in the industry, EBC Brakes.
EBC Brakes Racing aims to offer uncompromised braking products of the finest quality that offer unparalleled levels of performance on track days and in race situations.
EBC Brakes Racing RP-1™
One of EBC’s Most Extreme Brake Pad Formulas to Date
  • Superb modulation gives unprecedented control and feel throughout each braking event
  • Extremely low wear rate with stable friction coefficient, even under the harshest on-track driving conditions
-Pads come thermally bedded, eliminating ‘early-life’ fade and minimising bed-in time
-Stainless-steel backing plates reduce heat conduction, lowering caliper operating temperature
- Ideal for: track/race driving in lighter, heavily-servo’d cars [NOT ROAD LEGAL]
EBC Brakes Racing RP-X™
High-Performance Motorsport Race Pad
  • Extremely high friction coefficient across the entire temperature range
  • High initial bite and impressive brake power, all with reduced pedal effort
  • 100% brake effect from cold
- Ideal for: race/sprint driving in heavy, high-powered vehicles [NOT ROAD LEGAL]
EBC Brakes Racing 2-Piece Fully Floating Discs
High-Performance Two-Piece Replacement Discs
  • Fully floating design with all-aluminium hub to significantly reduce weight
  • SG grooves, directional curved vanes and SD-Drive bobbins for optimum track day/race capabilities and longevity
  • No vehicle modifications required with most applications
  • Ideal for: track day/race driving
EBC Brakes Racing Apollo Balanced Big Brake Kit
One Giant Leap for Braking Performance
  • Full ‘balanced’ kit featuring Apollo front calipers and other components for both front and rear axles
  • The ultimate upgrade when it comes to stopping power
  • Supplies a firmer and more responsive brake pedal feel
  • Complete with 2-Piece Fully-Floating Discs, various pad options, lines and fluid
  • Ideal for: fast road/track/race driving
GET YOURS
Shop the full range of EBC Brakes components at Where to buy EBC Products - EBC Brakes
@EBC Brakes UK do you guys think you'll expand to cover the pursuit cars? I didn't see any offerings for the BR9 package brakes when I out those in my car.
I ran yellowstuff pads on my Durango for years and they worked great, couldn't make those things fade if you tried.
Hi, Thanks for your question. If you email [email protected] with your question, He should be able to assist further and has a more in depth knowledge
