Dynatech shows a Dodge Magnum but these will also bolt onto the Charger and Chrysler 300C. Also covers all of the 2006 models. One person dynoed a 34hp/56ft-lb torque improvement with this package.
They don't have a package for the SRT-8 yet.
Why would you want to coat stainless headers?tbyrne said:The headers are uncoated stainless steel but that can be coated.
How it was explained to me is that the ceramic coating on the header tube allows two things to happen. First, the coating keeps reduce the amount of heat that "escapes" from the tubes. Keeping the heat of the exhaust contained within the tube allows for better convection which helps draw the exhaust out the chamber (better flow). The second benefit is that since more heat is trapped in the tube and goes out the tail pipe, there is a reduction of engine compartment heat.Stonebreaker said:Why would you want to coat stainless headers?
