Hi
I have a 2010 Dodge charger r/t. My master switch on the driver side does not roll down the passenger or driver side window. But it does roll down both rear windows. I can roll down the passenger side window but not from the driver side. Do you think its the master switch that I need to replace? I did open up the driver side door to see if anything was loose or disconnect ed but everything looked fine. Any advice before I buy a new master switch.
Thanks!
My 2010 had the same situation. The drivers side window did not work. Happened to be the wire connector inside the drivers door came apart..
Big John
Not sure if this is applicable to you or not:
SERVICE BULLETIN NUMBER: 08-061-12
GROUP: Electrical
DATE: November 29, 2012
SUBJECT:
Drivers And/Or Passenger Front Power Door Locks And Windows Inoperative U0200 Lost Communication With Passengers Door Module U0199 Lost Communication With Drivers Door Module
OVERVIEW:
This bulletin involves Inspecting the Drivers Door Module (DDM) and/or Passenger Door
Module (PDM) and replacing one of both if necessary.
MODELS:
2005-2010 (LX) 300/Charger
SYMPTOM/CONDITION:
The customer may experience any or all of the following conditions:
· The drivers and/or passenger front power locks and windows are inoperative.
· The rear window switches will work properly.
· The Technician may find Diagnostic trouble code (DTC), U0200 Lost communication
with Passenger Door Module.
· The Technician may find Diagnostic trouble code (DTC), U0199 Lost of
communication with Drivers Door Module.
DIAGNOSIS:
1. Using a Scan Tool (wiTECH™) check for a loss of communication with the DDM
and/or PDM.
2. Is there a loss of communication from the DDM and/or PDM?
a. Yes >>> Proceed to Step #3.
b. No >>> This bulletin does not pertain. Continue diagnostic following standard
service procedures.
3. Disconnect the battery for one minute, then reconnect the battery.
4. Using a Scan Tool (wiTECH™) did we regain communication with the DDM and/or
PDM?
a. Yes >>> perform the repair procedure.
service procedures.
PARTS REQUIRED:
Qty. Part No. Description
1 56038720AR Door module, Without Memory Seat, (JP3)
1 56038722AR Door module, With Memory Seat, (JP3+LEW)
1 04602838AE Door module, With Memory Seat and
Courtesy Lamps, (JP3+LEW+LEC)
REPAIR PROCEDURE:
1. Replace the DDM and/or PDM, per TechCONNECT 08 - Electrical/8E - Electronic
Control Modules/MODULE, Door/Removal and installation.
2. Calibrate the Windows, follow procedures in TechCONNECT 08 - Electrical/8N -
Power Systems/Power Windows/Standard Procedure.
3. Clear any codes that may have been set by the diagnostic and repair procedure.
POLICY:
Reimbursable within the provisions of the warranty.
Front windows not working from driver side
I have an 08 dodge charger r/t i was also having problems with my front window not letting down or up from the driverside switch. It will let the back windows down, but not the front windows. I tried replacing the switch and that didn't work. So it was late and we decided to just unplug the battery to see if that would work and yes it did. So just try to unplug the battery. I'm just one day in so i hope it lasts.
