CLARION MAX675VD Specification
* DVD±R/DVD±RW/CD-R/CD-RW/VCD ready
* MP3/WMA compatible with ID3-TAG display
* OEM Steering Wheel Remote Ready
* Bluetooth ® Interface Ready
* 8 Selectable Wall Papers
* 18 FM / 6 AM station presets
* DSP tuner with variable bandwidth
* iPod direct connection and control
* 2-Zone entertainment: Front and Rear separate source control
* 24-bit D/A converter
* 3-band parametric equalizer
* 50 W × 4 Built-in MOS-FET Amplifier
* Fully motorized 7-inch QVGA color LCD monitor
* Touch panel control with soil-resistant finishing
* Adjustable display brightness
* Phone mute
* 1 AUX AV input (2 ch audio + video)
* Video output for rear entertainment
* 6 ch RCA output and 2 ch RCA output for 2-Zone
* CCD camera direct input
* CeNET Control of: Navigation, 5.1-channel decoder, TV tuner, 6-disc CD changer and Satellite receiver
* 1 optical output
* RGB input for navigation
JVC Specifications
AV Systems
DVD Player KW-AVX710
Video Format NTSC
DivX(R) Compatible DivX(R) ULTRA Certified Product
DVD-R/-RW, +R/+RW Compatible Yes
Video DAC 108MHz/12-bit DAC
DTS/Dolby Digital/MPEG Audio Yes
GIGA MP3 MULTI Yes
JPEG/MPEG 1/2 Compatible Yes
Pause/Step/Slow Pause/Slow (Slow function remote only)
Direct Chapter Access Yes
Video CD Playback Yes
Frequency Response 16 - 22,000Hz (DVD fs=48/96kHz), 16 - 20,000Hz (CD)
Dynamic Range 93dB (fs=48kHz)
Signal-to-Noise Ratio 95dB (fs=48kHz)
Channel Separation 85dB (at 1 kHz, fs=48kHz)
Wow & Flutter Less than measurable limit
VCD Player KW-AVX710
Video Format NTSC
Video CD Playback Control Yes
Direct Track Access Yes (Remote Only)
CD Player KW-AVX710
MP3/WMA Compatible with ID3 Tag/WMA Tag Yes
WAV Compatible with WAV Tag Yes
CD-R/RW Compatible Yes
CD Text Yes
Random/Repeat Play Yes
CD Changer Control KW-AVX710
MP3 Control Yes (with CH-X1500)
CD Text Yes (with CH-X1500)
Bluetooth Control KW-AVX710
Bluetooth Control Ready (KS-BTA200 required)
Hands Free Call Yes
Audio Streaming Yes
SMS (Short Message Service) Display Yes
Phonebook Transfer Auto
Voice Recognition Dialing (voice recognition compatible cell phone required) Yes
iPod/iPhone Control KW-AVX710
iPod Control Yes (J-BUS)
Play / Pause / Skip / Search Yes
Text Yes
Battery Charge Yes (J-BUS)
iPod nano 1st Yes (J-BUS)
iPod mini Yes (J-BUS)
iPod 3rd Yes (J-BUS)
iPod with Click Wheel Yes (J-BUS)
iPod with Color Display Yes (J-BUS)
iPod with Video Yes (J-BUS)
iPod Video File Playback RCA-IN
Radio Tuner KW-AVX710
Tuner Type
HS-IV Yes
Preset Stations 18 FM + 6 AM
Station Name Registration Yes
SSM (for FM) Yes
AFNS/PNC Yes
Seek (Up/Down) Yes
Stereo/Mono Switch (for FM) Yes
Auto Antenna Yes
European Switchable Tuner Yes
FM
Frequency Range 87.5 - 107.9MHz
Usable Sensitivity 11.3dBf (1.0uV/75 ohms)
50dB Quieting Sensitivity 16.3dBf (1.8uV/75 ohms)
Stereo Separation 35dB
AM
Frequency Range 530 - 1,710kHz
Sensitivity 20uV
Selectivity 35dB
Amplifier KW-AVX710
Maximum Power Output 50W x 4
Continuous Power Output (RMS) 20W RMS x 4CH at 4 ohms no more than 0.8%
MOS-FET Amplifier Yes
Audio DAC 192kHz/24bit
Source-Specific Volume Control Yes
Volume Attenuator Yes
Balance/Fader Control Yes
Equalizer
7-Band iEQ Yes
Max. Amp Gain Switcher Yes
AV Input Terminals (Video + L/R) Yes
Line Output Terminals (pair) 1 Pair (Rear)
Composite Video Output Yes
Optical Digital Output Yes
Frequency Response 40 - 20,000Hz
Load Impedance 4 ohms (4 - 8 ohms allowable)
Pre-output Level/Impedance 2.5Vrms/1k ohms
Pre-output level/impedance 2.5V
Video Output Level/Impedance 1.0Vp-p/75 ohms
Video Input Level/Impedance 1.0Vp-p/75 ohms
Audio Input Level/Impedance 1.5Vrms/20k ohms
Monitor KW-AVX710
Screen Size 7-inch Wide
Touch-Panel Operation Yes
Screen Resolution 480 x 3 x 234
LCD Type TFT Active Matrix LCD
Color System NTSC
Display KW-AVX710
Contrast Control Yes
Switchable Dimmer Yes
General KW-AVX710
Face Type
Motorized Slide-Out Face Yes
Steering Remote Control Ready Yes
Wireless Remote Control Type Easy-Grip
Beep Tone Support Yes
COMPU PLAY Yes
Tel. Muting Yes
Power-Off Mode Eject Yes
Dimensions (W x H x D)
Installation Size 7-3/16'' x 4-3/8'' x 6-5/16'' (182 x 111 x 160 mm)
Panel Size 7-7/16'' x 4-5/8'' x 7/16'' (188 x 117 x 10 mm)
Weight 2.9 kg (6.4 lbs.)
