1 - 19 of 19 Posts
I am sick of the dealership - they are stupid and they do whatever they feel like doing. I was suppose dto have my pcv valve changed theis week and they "forgot"
I also went to another place to get my oil changed, they used 5w-30 instead of 20 - after a long argument, i got my money back.
I decided that for now on im doing this stuff myself. I can do my oil, i did my spark plugs. Now i need to do the following.
pcv valve
cabin filter
throttle body cleaning* dealer said i needed this because i was complaining about my car being sluggish.
how hard is it to do these repairs? i saw a thread on the cabin filter, looks pretty simple.
What about the PCV valve, i can buy it from the dealership - but do not want to buy it unless i can install it...
then the throttle body - im not sure how to do this.......
Thanks in advance!!!!
the throttle body cleaning the dealer talked about with you takes a special vacuum assembly, so to do a bg/wynns clean you cant do that on your own. All the rest is easy cheesy. Do not just go and spray things into the etc as a throttle cleaning. These things will screw up the etc and also can puddle in the intake manifold, bad news. Let them do the bg clean/fuel injector cleaning but everything else do yourself
Very simple. It is just connected by rubber hoses. Yank it out, insert new one.
Funny how they would forget to install a PCV. It shuold have been written on the work order. Take the car into a Chrylser dealer, not Dodge.
actually , this pertains to 5.7's- i dont remember the other motors, but the pcv valve is in a plastic canister at the passenger side back of the intake. You'll have to use some pliers to turn the cap off 1/4 of a turn and its inside.
well then i answered your question
Discussion Starter · #19 ·
i ended up replacing the PCV valve - no problem... ans sorry it wasnt the cabin filter that needed replacing it was the air filter.. I am notricing a huge difference is gas mileage since i changed the air filter..... i got 106 miles on my forst 1/4 tank... never has that happened before....
i looked in my car for the cabin filter and I dont see one in there....
1 - 19 of 19 Posts
