1 - 1 of 1 Posts
For Sale Ebay Item 290402178606
More Pictures HERE http://s810.photobucket.com/albums/zz29/dr440/
Video's HERE http://www.youtube.com/2112426gh
71" Dodge D100 with a Moser 8 3/4 rear 4:89 case, Auburn Posi with 4:10 richmond gears, ladder bars. Race 727 Torqflite with Cheetah Full Manual Valve Body w reverse shift pattern Kevler clutches and bands... 440 is strong with good compression rv cam edelbrock 4barrel, headers k and n air filter extra carb. Comes with factory fitted carpet kit, not installed. Brand new Hankook rear tires P295 /50r15 on Cragar aluminum wheels,
The Following are NEW: Battery, Hi flow water pump, oil and temp gauges, Oil pan and gaskets, Timing cover and gasket. Gas Tank, Gas Tank Sending unit, Fuel line, Mechanical Fuel Pump, Pressure Regulator, Filter, Carburetor, Jacobs Hi Output CDI Ignition Installed but not hooked up. Mini Hi Torq Starter wrapped in header fiberglass tape to prevent heat soak, starts hot or cold.
Needs some wiring work as the running lights come on when battery is connected. Truck drives fine but has a slight surge as you cruise, if you accelerate or decelerate the surge disappears..
I also have another 8 3/4 third member with 2.76 gears to make this truck more of cruiser / highway happy better gas mileage etc, this is used and was purchased at a local mopar show. If it doesn't work you have the guys phone number so you can call him to discuss a refund!!!!
I have the original edelbrock 4 barrel but currently I have a rebuilt edelbrock on the truck that works much better.
Brakes are drum all around and work fine No squeaks, haven't opened up to look at pads however.
This truck was bought on Ebay and was inspected by Auto Express in Eerie PA., They vouched for its condition in 2004:rocker:
1 - 1 of 1 Posts
