1 - 2 of 2 Posts
I've had my 2011 Dodge Charger Rally + for a couple months. When ever the gas tank gets between 1/4 and a 1/2 tank the engine light comes on. After I fill up if I press the push button start (without pressing break) 3 times really fast it will turn off next time I start.
Has anyone run into this? Is there a solution to prevent this light from coming on. The dealer suggested disconnecting battery to see if that does it. After that, it's a hard code an has to be taken in. Anyone try the battery solution, or know if it will work?
Not likely disconnecting the battery will fix it permanently, that's usually a sensor issue in the tank. I seem to remember seeing this issue somewhere else and the solution was a new fuel pump/sending unit.
1 - 2 of 2 Posts
