41 - 60 of 102 Posts
· Supporting Vendor
Discussion Starter · #42 ·
Will the 6000k HP48 fog lights match my HID lights? I never turn them on because I don't think they look good not matching the headlights.
Also just ordered some interior lights! can't wait to get them. Many recommend diode dynamics. I ordered from somewhere else off ebay and they sent a bunch of lights that don't even fit.
:rocker:
I recommend taking advantage of the Black Friday Sale and going with the XP80 or XML2 option. A 5000K XML2 will be the best match with your factory HIDs and provide significantly more usable output than your factory halogen bulbs.
It won't let me checkout it fails.
sent from death star
Please give us a call if you are having difficulty placing an order: (314) 205-3033
Our customer service team will make sure you are taken care of
Thank you!
Nick C.
· Supporting Vendor
Discussion Starter · #46 ·
I installed XML2 5k this past weekend in my 13 Charger R/T, what a difference nice an bright, great output matches headlights, stock bulbs don't even compare nor another set of plasma bulbs I've had from another.
Have you posted any pictures yet?
Thank you for the feedback!
Nick C.
Can you confirm which fog bulbs work with a 2012 Charger SRT? Your site says H11 for SRT but my owner's manual says PSX24W.
· Supporting Vendor
Discussion Starter · #55 ·
If you have the projector style fog lights, it should be an H11 sized bulb. The other models use the H16/PSX24W size. Feel free to give us a call for more clarification: (314) 205-3033
Thank you!
Nick C.
· Supporting Vendor
Discussion Starter · #57 ·
What are the operating temperature extremes both high and low for your products? Will they go down to - 30?
Sent from my SM-G930W8 using Tapatalk
Our engineering team utilizes an extreme temperature and humidity test chamber to ensure our products will work perfectly in both extreme heat and cold.
They are tested as low as -50*C and 180*C to ensure they will work in the coldest environments (like Canada) and the warmest climates.
Thank you,
Nick C.
