1 - 1 of 1 Posts
As the world leader in motorsports chassis dynamometers and diagnostic equipment, Dynojet Research Inc. is pleased to announce the Dynojet Wide Band 2, the second generation of Dynojet's popular Wideband Air/Fuel Ratio Monitor kit with digital technology and quickest response in the industry. All of this comes with a lower price and a more compact package.
The Wide Band 2 provides a complete picture for proper air-to-fuel ratio analysis.
The Wide Band 2 includes the following:
• 1 Wideband 2 Module
• 1 Data Acquisition Cable (optional with 15-7011 kit)
• 1 Bosch LSU 4.2 Wide Band Oxygen Sensor
• 1 Oxygen Sensor Cable
• 1 Oxygen Sensor Weld Bung, Plug, and Copper Washer
• 2 Dynojet CAN-Link Port Seal
• 3 Wire T-taps
• 1 Terminal Strip Plug
• 2 Dual Lock Strips
• 1 Alcohol Swab
• 3 Zip Ties
• 1 Warranty Registration Card
• 2 Dynojet Decals
• 1 Installation Instructions
Wide Band 2 Options:
• Dynojet LCD Full Color Touch Screen Display
• White or Black Analog Gauge, 52mm (2 1/16”)
• White or Black Digital Gauge, 52mm (2 1/16”)
• Data Acquisition / Gauge Combination Harness
• Dynojet CAN-Link Cable
Wide Band 2 Technical Features:
• 0-5v Calibrated Analog AFR Output (Connects to external data acquisition device)
• One wire RPM hookup
• 0-5v analog input (TPS, MAF, boost, etc…)
• Built-in Sensor Condition Test
• Durable enclosure and wire sheathing for years of trouble-free operation
• Dynojet CAN-Link communication, allows for expansion options
Wide Band 2 Product Specifications:
• Power Requirement 11.5 - 15 VDC, 3A
• Dimensions 2.80"w x .56"h x 1.488"d
• Range: .68 lambda - ambient air
Inputs:
• Analog: 0-5 VDC
• Digital Square wave, 0 - 12 V nominal (coil (-) tachometer signal)
Outputs:
• Gauge Driver 0 - 5 VDC analog
• Calibrated AFR 0 - 5 VDC analog
• Simulated Narrow Band
• Dynojet CAN-Link (accessory cable required)
Pricing:
15-7003 WB2 - Base Unit $249.00
15-7018 White Analog 52mm Gauge $69.00
15-7019 Black Analog 52mm Gauge $69.00
15-7020 White Digital 52mm Gauge $69.00
15-7021 Black Digital 52mm Gauge $69.00
LCD-200 LCD Touch Screen Display $299.00
ChargerForum.com forum members receive an additional 10% discount off these prices!
For additional information, check out the WB2 website at http://www.dynojetwb2.com
If you have any further questions, you can PM me here, e-mail us at [email protected] or call us at 800-992-4993.
1 - 1 of 1 Posts
