I have a alpine headunit with 2 JL audio subs and a pioneer amp when i turn up the radio I notice my headlights and dash lights have slight pulsating look and I know some people with say to throw a capacitor in it but I've done research on capacitor I've read many thing that say there just not worth it anyone got any suggestions or thoughts? (And I don't want to turn the radio down)
No one should tell you to add a Capacitor. There is a few things you can do till the problem gets fixed..
1. Turn down your Gain on the Amp.
2. BIG 3
3. Upgrade Stock battery to a Larger AGM battery
4. Add 2nd Battery
5. Upgrade Alternator
But before you do anything. What Amp do you have? Whats your Gain at? and how are your Subs wired?
Whats a big 3 idk what my gains at ill have to look and I'm running 8 garuage I believe I had a place do it and was very unhappy I should have just done it myself
Post up what Amp you have and what Ohm your Subs are wired.
Use this to help
http://www.the12volt.com/caraudio/woofer_configurations.asp
The BIG 3 is...Try the first 2 first. Cheap and easy..
1. Upgrading your Battery Ground by adding a 1/0 Ground.
2. Adding a 1/0 Ground to your Alternator.
3. Adding 1/0 Power from Alternator to Battery
You can either buy this kit..
http://www.mechman.com/accessories/batteries/20-foot-long-1-0-zero-gauge-battery-cable-kit/
or Make your own from 2/0 Gauge Welding Cable. I say 2/0 because most good Audio Cable is oversized. That Mechman man is actually closer to 2/0..
Go through my Audio upgrade thread here. I'm going through many of your questions in my thread.
http://www.chargerforums.com/forums/showthread.php?t=261553
Here is a wire comparison picture I took a couple weeks ago..
Here is Wire Comparison
From left to right
Mechman 1/0 Power
Mechman 1/0 Ground
NVX 1/0 OFC Ground
NVX 1/0 OFC Power
TryStar 1/0 Welding Wire
