1 - 2 of 2 Posts
If I ordered my Diablo with a T-stat is it pre programmed with the adjusted parameters? My temp rarely goes over 205 now and I have not put the new T-stat in yet. Is that normal?
Around 205 is where the stock thermostat opens and lets the coolant flow through the radiator. If it is pretty warm out and it rises higher, the fans come on to help cool it. If you put a 180 in, it all happens the same way but at 25 lower temp. You need to program the tuner to run the fans at the lower temp.
1 - 2 of 2 Posts
