nicely done:bigthumb:
Car looks good man, I really wana do my car too. Also where did you get your eibach kit from?I'm gonna say it again..... I really need the Eibach kit to get here!!
I ordered mine through TireRack because they ship to APO/Germany. It should hopefully be here next week.Car looks good man, I really wana do my car too. Also where did you get your eibach kit from?
Now if you would have ordered it through Adam's, you could have used my coupon code "Junkman", and gotten 10% off that purchase, plus some Fine Machine Car Polish which is a lot more concentrated than the stuff you used today. When using the PC, you must remember that one application may NOT fix all of the problem. It may take more applications, however, using the right and effective compounds will cut down on how many passes you must make.It's much better than the Craftsman Buffer I was using!! I ordered mine through Autogeek.
1 DTB-100-AG - Detailer's Tool Bag 45.00
(Autogeek)
1 HK-7424-CCS-1 - Porter Cable 7424 & Pad Kit 199.99
(Standard)
I know :slap: I need to call Adams to get the stuff shipped here. I definitely need something stronger among other things they have. 5 different Meguires, Turtle wax stuff isn't good enough, I did the hood 6 times today. Tommorow when the sun is back out I'll see where I'm at compared to today.Now if you would have ordered it through Adam's, you could have used my coupon code "Junkman", and gotten 10% off that purchase, plus some Fine Machine Car Polish which is a lot more concentrated than the stuff you used today. When using the PC, you must remember that one application may NOT fix all of the problem. It may take more applications, however, using the right and effective compounds will cut down on how many passes you must make.
This is what you need. The Fine Machine Polish is concentrated so it doesn't take a lot. Read the instructions before you use it. Do not apply it in direct sunlight. The car's finish needs to be cool or it will dry too fast while you're working with it. Also, use some detail spray to spritz your pad as the scratches and swirls diminish. Then come behind that with a white pad and some SHR. Last of all, finish with the black pad and some Superwax.I know :slap: I need to call Adams to get the stuff shipped here. I definitely need something stronger among other things they have. 5 different Meguires, Turtle wax stuff isn't good enough, I did the hood 6 times today. Tommorow when the sun is back out I'll see where I'm at compared to today.
:beerchug:
You'll be so shiny that satellites in space will be blinded!
If you were closer, I'd show you how to do it first hand. Alas, that pond between you and I is a tad deep I hear...lol, Thanks Junkman. I'll get my order straight in the morning. It's good to know we have you around here for some sound advice and guidance!
