I currently have the Beats Audio system. I was hearing alot of noises in my speakers and found out my passenger side dash speaker was burst... Anybody know the best 3.5 inch speakers to get to put in the dash...
Best fit for the Charger for OEM replacement aftermarket is the Infinity Reference 3002 3.5". It is 2 Ohm like the rest of your speakers so there will not be any loss of volume with a 4 Ohm speaker. They have the proper clearance to fit under the stock grill.
They will sound so good it is likely you will be forced to do a whole system upgrade! Sonic Electronix has a good price, Crutchfield will provide you with the adapter hardware you need as well so you net about the same price, maybe a little cheaper. Bought from both and both are good retailers with lots of help.
Do you know which Infinity Reference 3002 fits because all the ones I see are 4 ohms....
Infinity calls it "true 4 Ohm" because with most small gauge harness wiring there is more resistance in the line so the amp sees about 4 Ohm. The Infinity speakers are 3 Ohm (My 3032's measured less than three). By comparison, the Kicker OEM upgrades measure 3.7 Ohm. This is from memory, I didn't write down the numbers when I measured. But I can confirm if you like. I have 3002cfx and the stock tweets.
Yes, if you work through the Crutchfield fitment tool on line, that is probably the only option that comes up. Mainly due to the fact that the infinity have a small mounting height to fit under the dash grill cover. But it is not settling for less. These are good speakers and you'll have to spend a lot more money to get noticeably better speakers.
OK, if you need help with the R&R let me know. I advise using a small thumb ratchet for working the screws. It's a tight fit under the windshield. I just checked Crutchfield and they are out of sock, but I recommend getting the Metra 71-039C Speaker Wiring Adapters from them. This makes the job super easy. Call them up and they might include the instruction sheet as well.
Mark
Yay WalMart!
