1 - 2 of 2 Posts
I'm new to this wiring thing, so I have a question. How do you tap into the cigarette lighter to supply power to the cutouts? Also, do you have to drill holes in the firewall to insert the cords to the desired switch location, or is there a hole already available?
You can use any of the numerous body plugs under the vehicle. You will have to remove seats to get thru the carpet. You can use the power supply in the center console as well. Search for RT Junkie no esp mod for detailed instructions on how to remove the console to get to the underside of it.
1 - 2 of 2 Posts
