1 - 4 of 4 Posts
Carid has kits for the interior, don't know if you can get just the steering wheel pieces or not. Probably can. But you can also Plastidip them. That way if you don't like the color you've chosen, you can just peel it off and start again, or not. I did my radio bezel. I'll be doing my steering wheel and the silver bar over the glove box.
Everyone says to remove the pieces and PD them outside of the car, too many fumes. There's a thread somewhere that says to to remove them, you'll have to search on that.
On the back of the steering wheel there are 2 screws (10mm) just take them off and the front of your steering wheel will slide off. Just take a flat head screw driver and pry them out. BEFORE YOU DO THIS UNPLUG THE NEGATIVE ON THE BATTERY!! Just to prevent the airbags from deploying. The center just pops out, I grabbed it between the vents and pulled. The right part comes off by popping it out with a flat head screw driver. If you are going to do the door panels there is a write up on how to remove them by removing the plastic welds and blah blah, it's in the forum. Good luck brotha. Post some pics when you are done.
and btw.. I'm the dab king! haha wax to the face!!! JK, but fa real tho..
1 - 4 of 4 Posts
