Now if only the halos were here....
http://www.youtube.com/watch?v=EQi20dw3YXk
Will post new vid when they come in.
If you are having trouble reading the notepad: The outer lights represent the white rings on right and left of car and inner are the red rings...
Made it outta some parts I had laying around....
lol
:rocker:
4 switches:
Functions are:
default (no switch activated) : Whites on with ignition. This activates when I unlock doors with fob or hit remote start. All other functions will be same way if "left on"
switch one is whites bypass (off)
switch two is reds on
switch three is whites transfer to flasher module
switch four is reds transfer to flasher module
transfers are done with relays to protect the circuits and from backfeeding ignition circuit i tapped into is also protected by a relay. This box will fit in the center console.
The flasher module itself is 3 functions "cop strobe" (8 flash per side alternating sides); wig-wag (flash back and forth); and flash all at once.
For show purposes only, obviously. Thinking of even making a quick disconnect for this control to quickly trade out between this and a stripped down version with no flasher circuitry so I can't get in trouble with Johnny Law
lol
:rocker:
4 switches:
Functions are:
